TwinTurbo.NET: Nissan 300ZX forum - ^ Try cleaning the connection.
CoHPhasor
on January 05, 2011 at 11:57 PM
It's not the sensor; it's the connection. (n/m)
posted by NytWolf
on January 05, 2011 at 11:36 PM
When the CTS tells the ECU the water temp is low the ECU runs a richer map to help keep the car running at those temps.
finally got the car back together after upgrading the
scooter4zx
22:07:50 01/05/11
I figured out the hose it went to the little solenoid thing
scooter4zx
22:19:40 01/05/11
Check your water temp sensor. (n/m)
Wright (Ca)
22:32:42 01/05/11
coolant temp sensor is ohming out at 1.5 ohms at 70 degrees.
scooter4zx
22:54:54 01/05/11
NytWolf
23:36:35 01/05/11
^ Try cleaning the connection. -
CoHPhasor
23:57:16 01/05/11
Sounds like you're running super-rich.
CoHPhasor
22:53:40 01/05/11
the vac line is definitly on the fpr.As for a pinched oring,
scooter4zx
23:00:22 01/05/11
would a bad 02 sensor cause excessive smoking? (n/m)
scooter4zx
23:01:58 01/05/11
Another thing I just realized.When I ordered the chip from
scooter4zx
23:15:05 01/05/11
If the O2 reported lean when it wasn't, yes.
CoHPhasor
23:55:42 01/05/11
its not the chip. you are running so rich that looking at
tognot
11:29:03 01/08/11
my dumb ass installed the chip backwards.I had to send the
scooter4zx
16:51:04 01/08/11
